frankjohn
#1 Posted : Saturday, July 17, 2010 1:15:47 AM(UTC)
frankjohn
Everything in the freezer is starting to defrost. Ice cream is getting soft, ice is starting to melt, etc. Refrigerator seems fine. what next?
#2 Posted : Saturday, July 17, 2010 6:07:18 AM(UTC)
Remove the back cover and check to see if the compressor is running. It will be hot and make a distinct humming noise, and the small diameter tubing will be hot.
frankjohn
#3 Posted : Saturday, July 17, 2010 9:20:31 AM(UTC)
frankjohn
Removed back panel and compressor is running and is hot. The fan under the freezer is also running. Ice cream is gettiing softer and frozed waffles are starting to thaw. Steaks are still frozen but I don't k now for how long.
#4 Posted : Saturday, July 17, 2010 9:32:55 AM(UTC)
Probably a bad compressor or refrigerant leak. It is covered under your 1 year warranty.
GE fridge/freezer freezer is defrosting and not freezing anymore (Refrigerator & Freezer Repair)
by booomer 4/5/2009 10:51:00 AM(UTC)
