greg362
#1 Posted : Monday, August 4, 2008 10:37:09 AM(UTC)
greg362
My dryer will ignite, but the flame goes out after about 8 seconds. It will reignite and do the same. It will go through this cycle several times, then it won't reignite. I have cleaned the exhust system in it's entirety. I have replaced the valve coils. I have jumped out each of the three thermostats with no luck in detecting the problem. Any ideas?
#2 Posted : Tuesday, August 5, 2008 10:39:18 AM(UTC)
Hi Greg,
Check the blower wheel (#201 on the break down diagram) and air ducts inside the dryer.
