On spin cycle water is coming back out of balance ring in the top. The seal to the tub is ok. If you stop the rinse cycle after is starts to leak then restart it does not throw the water. Was thinking it was an overfill issue but that does not seem to be the case although i can not say for certain. Could it simply be something with the balance ring? Any help would be appreciated.
thanks al
