harrychoy
#1 Posted : Thursday, July 15, 2010 9:08:04 PM(UTC)
harrychoy
Lights on door control went out. Thermal fuse is ok. Replaced control board and all was well for 1 cycle. 2 days later, lights on door control are again dark.
- door switch tests ok
- there is power to door switch and control board
- thermal fuse tests ok
What should I check next?
Thanks!
a.ung
#2 Posted : Wednesday, December 15, 2010 11:35:01 AM(UTC)
a.ung
I have the same issue on my KUD102FRSS. Machine stopped mid cycle, with no lights on the display. Confirmed that power from the outlet is still live. Can someone guide me as to where the thermal fuse is located. Thanks.
a.ung
#3 Posted : Wednesday, December 15, 2010 11:48:19 AM(UTC)
a.ung
8194590 lower rack instruction sheet.pdf (684kb) downloaded 61 time(s).I removed the door and taken the attached pic.
a.ung attached the following image(s):
Case
#4 Posted : Sunday, March 20, 2011 8:03:42 AM(UTC)
Case
I have a similar problem with my kudp01flss6 and when I took the front panel off I found one of the "dogs" going to the switch attached to the active vent, top left in above photo, very loose.
Could this also prevent the unit from starting?
