allyn workman
#1 Posted : Tuesday, July 13, 2010 8:08:31 PM(UTC)
allyn workman
Amana refrigerator has water going to the machine as the water comes out of the front of the refrigerator to fill a glass. The problem is that the water is not getting to the ice maker. What would be possibilities for trouble shooting the problem? The refrigerator is cooling and freezing properly.
pete860
#2 Posted : Monday, August 16, 2010 12:46:51 PM(UTC)
pete860
My amana ice maker stops working all the tiime. To fix it I remove it and check that the line running into the ice maker is not frozen and I remove the frozen ice from the ice maker. It seems that the levers that remove the ice get frozen up in the ice maker. To keep this from happening again you may want to kick up the freezer setting by one. If you kick it up too much, the water line will freeze.
