Rheem Two ton gas pack unit, less than one year old. The compressor makes a boom or thud every time it kicks on...to the point it keeps me awake. My old one didn't do this. I called someone out and he said I needed a new fan blade which he installed. It changed nothing. I am at my witts end. I don't know what to do. It is under warranty, but they don't seem to find the problem. Is there one or is this typical?
Check the compressor mounts. Maybe some packing material has not been removed from the install.
The Right Way HVAC Fall Maintenance To Do
(Heating, Ventilation, and Air Conditioning (HVAC))
by Guest
9/29/2021 10:29:07 PM(UTC)
HVAC damper motor
by cchen2
12/26/2016 7:08:59 AM(UTC)
Buying used HVAC system, good idea?
by AppUser1
2/4/2014 12:28:28 PM(UTC)
Hvac Blower motor problem
by jaywalker1981
9/12/2013 12:51:55 AM(UTC)
GE zoneline hvac
by pmsage
12/27/2012 10:59:13 AM(UTC)
hvac unit gas
by hev-v
12/23/2012 4:18:10 AM(UTC)
home hvac system wired wrong and shorted, help
by hglarry
7/31/2011 1:32:12 PM(UTC)
Can a gas hvac be converted over to electric?
by justonelaw
6/14/2010 8:23:17 AM(UTC)
HVAC heat elements stay on
by mooney99
2/24/2010 2:44:15 PM(UTC)
Gas Valve On Lennox Hvac...bad???
by F1RUETER
11/3/2009 5:19:28 AM(UTC)
Magic chef hvac wall unit blower wheel
by geiserberner
1/30/2009 1:35:28 PM(UTC)
HVAC not working after switching to new digital thermostat?!?
by gaber79
11/18/2008 9:06:12 AM(UTC)
HVAC Blower is going nuts
by halapeno
11/25/2007 9:47:37 AM(UTC)
