bejo38
#1 Posted : 15 years ago
bejo38
The 5 8 and 9 front panel touch buttons suddenly stopped working. Anyone have this problem. I am wondering if the front panel with touch buttons alone should be replaced or if the control board alone should be replaced or both to fixed the problem. Has any had this problem and fixed it?
bejo38
#2 Posted : 15 years ago
bejo38
I fixed it myself. I took the panel apart and cleaned the flex circuit board connectors from the push button switches to the control panel pcb and it works again. I will watch to see if that is a permanent fix.;)
