My dryer won't heat, but still spins. The only thing I've tried is to reset the fuse on the wall.
What would be the first thing you would try or replace?
Groups: Expert
I would make sure you enough power coming through the cord to the dryer. Then if not I would check the thermal fuse then the heater....goodluck
How would I go about telling if the Thermal Fuse is blown? Also can someone link me to a guide for opening my dryer?
Groups: Expert
Just unplug it and take off the back panel with the 1/4 nut screws and take one wire off the thermal fuse and check it for Continuity with a volt meter...
Originally Posted by: Brevard Appliance Repair  Just unplug it and take off the back panel with the 1/4 nut screws and take one wire off the thermal fuse and check it for Continuity with a volt meter...
So I took off the back. Now there are two metal holdings behind that. Which side holds the fuse?
Groups: Expert
is this a gas or electric dryer....the fuse should be visible when you take the back off it a white bar like object with 2 wires coming from it...
Originally Posted by: Brevard Appliance Repair  is this a gas or electric dryer....the fuse should be visible when you take the back off it a white bar like object with 2 wires coming from it... Its an electric dryer. I'm also testing the heater coil. Is there a certain tool I should be using to remove the wires? They are on very tight.
Ok I found the fuse, thanks for the tip. I'm still having trouble taking off the wires attached. Is there a certain method I should be using? Don't want to break my dryer beyond my own means of repair. :)
I got the wires out with some force. I tested the fuse first, and got a reading. I moved on to the heating coil which had three wires attached to it. I removed them all and am getting a reading while testing one of the connections with the others. Would you know which two ends I'm suppose to be testing on the heating element? It looks like my dryer is more of less the same as this diagram. Bulkhead parts replacement parts for WHIRLPOOL LEN2000KQ1 29"electric Dryer | AppliancePartsPros.comEdit: Here is a picture of the coil.
