tru023
#1 Posted : Sunday, July 11, 2010 9:43:46 PM(UTC)
tru023
I bought this fridge and hooked the water line up to the back, when i opened the freezer I realized the water was just pouring in the back where it is entering the ice tray. The only way I could stop it is to turn off the main water supply. Does anyone have ideas.
#2 Posted : Monday, July 12, 2010 5:25:38 PM(UTC)
Remove the wires from the water valves on the back of the refrigerator. If the water will still coming in, replace both water valves.
If the water will stop, replace the ice maker.
Here are the breakdown diagrams and Replacement parts for MAYTAG MZD2768GEB Ref - SXS/I&W | AppliancePartsPros.com
tru023
#3 Posted : Monday, July 12, 2010 6:38:07 PM(UTC)
tru023
I've removed the dual water intake valve and will be replacing it at soon as the part comes in. I sure hope this is what is wrong.
#4 Posted : Tuesday, July 13, 2010 3:38:36 PM(UTC)
There are two water inlet valves: before the filter and after the filter. Replacing just one of them could not fix the problem.
tru023
#5 Posted : Thursday, July 22, 2010 3:39:08 PM(UTC)
tru023
I changed the one down under the fridge and the water is sti pouring out of the ice maker. Now I'm not sure what to do?
#6 Posted : Thursday, July 22, 2010 7:02:39 PM(UTC)
Looks like it was not enough. The second water valve has to be replaced too.
tru023
#7 Posted : Thursday, July 22, 2010 7:10:17 PM(UTC)
tru023
should I unplug the fridge too?
#8 Posted : Thursday, July 22, 2010 7:14:09 PM(UTC)
Every time you work with any electric appliance, you have to unplug it. If you unplug a refrigerator, you have to wait at least 10 minutes before you plug it back.
