Ed Vuolo
#1 Posted : Friday, July 9, 2010 11:29:07 AM(UTC)
Ed Vuolo
I have replaced the mother board, AP4436216, the assembly board te board, AP3160651, the Interface disp, AP3203232 and the Damper assembly, I don't have the part number readily available at this time.
However the problem I have is the temperature settings will not work. When I push on the button for refrigerator temp. or freezer temp. it beeps but does not change the temp. Right now the freezer temp. reading on the display board shows 999, and refrigerator temp. shows 333. What possible can be wrong??
Do I need to order part AP3796807? If so that gives me another motherboard.
Please help me out I am so up set about the GE refrigerator.
Thanks for your help,
Ed Vuolo
#2 Posted : Friday, July 9, 2010 5:27:25 PM(UTC)
Ed,
What are the real temperatures in the freezer and in the refrigerator?
Very likely the problem is a bad user interface (key panel) which comes as a part of the electronic service kit only.
The electronic service kit Part number: AP3796807
you posted, is the correct part number.
Here are the breakdown diagrams and Replacement parts for General Electric PSS25NGMDCC Refrigerator | AppliancePartsPros.com
Quote:
...it beeps but does not change the temp. Right now the freezer temp. reading on the display board shows 999, and refrigerator temp. shows 333...
If this was the original problem, why did you replace the damper assembly and the dispenser interface control?
Ed Vuolo
#3 Posted : Monday, July 12, 2010 8:18:32 AM(UTC)
Ed Vuolo
Gene,
The temperature in the refrigerator is 33 degrees and the freezer is 0 degrees.
The reason I replace the dispenser interface control , the damper and the motherboard is because I had a GE repair man come in and he replaced the disp. solenoid. When the refrigerator keep freezing up he came back and told me that I needed a damper, a motherboard and the interface control. He said it 's probably not worth fixing. I could buy another frigerator for what it will coast.
I don't think I'll call him again. He just seems like he wants to sell me another refrigerator.
Thanks,
Ed Vuolo
#4 Posted : Monday, July 12, 2010 1:34:05 PM(UTC)
Ed,
The correct temperatures in both compartments show that there is nothing wrong with the cooling process and the only problem is a bad user interface.
The diagnosis made by this GE guy looks more like a guessing.
Ed Vuolo
#5 Posted : Tuesday, July 13, 2010 7:22:26 AM(UTC)
Ed Vuolo
Gene,
If I replace the user interface board do you recommend that I put the new motherboard in with it. Now I will end up with three motherboards. The orginal, which is probably still good, the new one that I bought and you told me that the interface board is not sold seperately, it comes with the motherboard. So do you think I should put the new motherboard in the the interface board?
Let me know. Thank you very much for all your advice.
Ed Vuolo
#6 Posted : Tuesday, July 13, 2010 3:08:20 PM(UTC)
Ed,
I would install everything included in this kit. You can try to return the previous main board. If you purchased it from Appliance Parts Pros, I do not think it will be a problem.
Ed Vuolo
#7 Posted : Tuesday, July 27, 2010 10:30:50 AM(UTC)
Ed Vuolo
I now need a replacement part for my GE refrigerator Model #TBF17SCBL. What I need is the pin and door hinge pivot socket. In your diagram for that model under Cabinet Parts it shows item 279 and 281, but I do not see the socket that goes into the refrigerator door to hold the item 279 in.
This looks like a pretty standard item. It's the door hinge that holds the freezer and refrigerator door with the insert that fits into door.
#8 Posted : Tuesday, July 27, 2010 6:20:09 PM(UTC)
Looks like this part is no longer available.
GE Profile Arctica Fridge too cold (won't set above 28F) (Refrigerator & Freezer Repair)
by Rocket Rider 2/20/2021 1:47:57 PM(UTC)
GE Profile Arctica: ice/water dispenser panel dead (Refrigerator & Freezer Repair)
by Bogeyfreerfk 1/15/2016 1:07:28 PM(UTC)
GE Profile Arctica PTS22LCSARWW no sounds not cooling (Refrigerator & Freezer Repair)
by dar@unforgettable.com 10/22/2014 10:17:40 AM(UTC)
Freezer And Fridge Not Cold Enough - GE Profile Arctica (Refrigerator & Freezer Repair)
by lakeober 7/14/2013 8:43:21 PM(UTC)
Water and Ice not working on GE Profile Arctica (Refrigerator & Freezer Repair)
by dwcrossett 11/30/2012 3:21:27 PM(UTC)
GE Profile Arctica - capacitor burning smell (Refrigerator & Freezer Repair)
by CF3501 10/10/2012 4:57:57 PM(UTC)
GE Profile Arctica ice maker (Refrigerator & Freezer Repair)
by mmmcarroll 9/6/2012 11:13:52 AM(UTC)
GE Profile Arctica Fried the brand new Main Board (Refrigerator & Freezer Repair)
by Nightmare 6/22/2012 11:10:02 PM(UTC)
GE Profile Arctica Refrigerator Not Cooling or Freezing But Running (Refrigerator & Freezer Repair)
by mGalicia 5/29/2012 3:15:30 AM(UTC)
by dstump 11/23/2011 10:48:04 PM(UTC)
GE Profile Arctica Fan Clicking in Freezer (Refrigerator & Freezer Repair)
by Samson10 10/6/2011 8:33:22 PM(UTC)
GE Profile Arctica not cooling, panels don't work (Refrigerator & Freezer Repair)
by johndoe111 7/31/2011 7:33:27 AM(UTC)
GE Profile Arctica Refrigerator Not Cold Enough (Refrigerator & Freezer Repair)
by Snap50 7/25/2011 6:11:51 PM(UTC)
GE profile arctica (Refrigerator & Freezer Repair)
by jasperfish 5/18/2011 6:14:19 AM(UTC)
ge profile arctica freezer temp 11 frig temp 39 (Refrigerator & Freezer Repair)
by jett40 5/4/2011 1:59:00 PM(UTC)
