llleighton
#1 Posted : Friday, July 9, 2010 8:36:42 AM(UTC)
llleighton
All the buttons on the button bar work except the start button. Resistance on the control board indicate button is working correctley, correct input voltage to the the board. Switched out the control board with a new one still not working. Any advice?
#2 Posted : Monday, July 12, 2010 5:02:39 PM(UTC)
Check the door switches and make sure they are properly engaged when the door is latched.
DianaW
#3 Posted : Tuesday, August 3, 2010 7:36:32 PM(UTC)
DianaW
I'm having the same problem. I can set the cycle, but the Start button does not light up when pressed. Nor does the delay button. The cycle button all light up.
Jenn air JDB1105AWS
