David Melvin
#1 Posted : Wednesday, July 30, 2008 2:09:13 PM(UTC)
David Melvin
Noticed a leak coming from the drain valve shaft next to the solenoid . While removing the the small cupped metal retainer to access the rubber seal the shaft pulled out. The shaft is nurrled on one end and has a flat side. when I tried to put it back in the shaft spins freely. I assume that the shaft has one flat side to lock into something. I know I need to replace the seal but how do I get the shaft back in correctly ? are there any additional parts I need to order.
Please help
David
abadfish66
#2 Posted : Wednesday, July 30, 2008 2:31:52 PM(UTC)
abadfish66
There is not a way that I know of to put it back together. You will need a new motor assy.
