MIKE@mikecolson.com
#1 Posted: : Wednesday, July 7, 2010 10:35:36 AM(UTC)
MIKE@mikecolson.com
Electric sounds are made when activating dryer but barrel does not turn. Dryer relatively new (3 yrs). Any suggestions? Is there are trouble shooring list I can go thru? Mike
#2 Posted : Wednesday, July 7, 2010 4:54:56 PM(UTC)
Mike,
If the motor works but the drum does not turn, most likely the problem is a broken belt.
- The belt Part number: AP2946843
MIKE@mikecolson.com
#3 Posted : Thursday, July 8, 2010 8:45:21 AM(UTC)
MIKE@mikecolson.com
Thx Gene. Barrel has tension on it so I think belt is intact. Could the motor be fried ? If so, is it better to have service call? And who is best to call. Bought unit at Lowe's and no warranty left. Mike
#4 Posted : Thursday, July 8, 2010 2:48:00 PM(UTC)
Mike,
Open the door. While pushing and holding the door switch, push the start switch and the same time turn the drum manually. Post the results.
