every 20 to 30 mins. the two door middle and only the front part of the divider between the two compartments is hot. on and off. BY THE WHEATHER STIPE MAY MELT.
please advice what the problem may be! call me @ (956)712-1286 or send me a e-mail
thank you, Mr. Limon
Hi mr.limon
The first thing I would check is condition of the condenser coil (located under the fridge). Most likely it needs cleaning.
Also check the freezer temperature, you may have some other problem. Freezer should be below 10 degrees.
