rafaelgm
#1 Posted : Tuesday, July 6, 2010 5:13:45 PM(UTC)
rafaelgm
The dryer starts but does not heat. I tried all the different cycles and it won't heat.
Also, when it starts, it keeps going and does not stop.
Suggestions?
Thanks!
#2 Posted : Wednesday, July 7, 2010 5:04:41 AM(UTC)
Replacement parts for WHIRLPOOL LER5620KQ1 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528187.pdf
Sounds like you are not getting 240 volts to the unit.
The reason I say this is that on this unit in timed dry the timer runs off the 240 volts directly (TM/WB timer contacts closed). You said you tried all modes and it will not advance or heat and both of theses require the 240 volts.
Try flipping the breaker off/on slowly a couple times, sonetimes you can loose half the line without actually tripping the breaker.
rafaelgm
#3 Posted : Wednesday, July 7, 2010 5:11:57 AM(UTC)
rafaelgm
Thanks denman.
I've tried switching the breaker on/off but it didn't work.
Do you think I should replace the timer?
#4 Posted : Wednesday, July 7, 2010 3:35:32 PM(UTC)
No, I would invest in a meter or get a friend to check it for you.
Just putting parts into a unit without some further troubleshooting will just cost you money.
Also on the timer the heater contacts in the timer and the timer motor would have to have gone bad at the same time and this is unlikely.
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Once you confirm that the unit is getting the correct power using AC volts scale, you can use the meter to find the faulty part using ohms (unit unplugged) which is much safer that trying to locate a bad part with power on.
rafaelgm
#5 Posted : Wednesday, July 7, 2010 3:51:31 PM(UTC)
rafaelgm
you are absolutely right!
I'm only getting 120V.
