Freezer temp is not maintaing the -2 to -10 degress F and therefore, the refrigerator is not cold either. Changed the defrost thermostat and defrost control. Checked heaters and they are good. It worked for 4 days and when we put things in the freezer that were already frozen it started warming up within 12 hours.
What else can be done?
Originally Posted by: Gene  We already cleaned them, but the fan was running slow the first time we changed the defrost control. We will check it out and let you know. Thanks.
