twangme7
#1 Posted : Tuesday, July 6, 2010 12:04:30 PM(UTC)
twangme7
Last week I found a puddle of water on the floor around our washer, Kenmore washer series 80 model #110.23832100. After moving it outside & examing the floor it seems the washer has been leaking for awhile as the floor was saturated down to the subfloor & insulation and then into another room. I figure whatever was leaking finally let loose and dumped water on to the floor. I haven't taken it apart yet but I looked underneath and saw a leak near the pump but can't really see much. Before I start tearing it apart (and possibly breaking something) do you have any ideas where I should start? What part(s) would break and dump water? Thanks in advance.
#2 Posted : Tuesday, July 6, 2010 3:04:11 PM(UTC)
Most likely the problem is a bad water pump. You have to remove the washer cabinet to access it. The instructions are attached to the reply.
- The water pump Part number: AP2907492
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 47 time(s).
How to remove the pump.doc (25kb) downloaded 34 time(s).
twangme7
#3 Posted : Wednesday, September 8, 2010 10:25:06 AM(UTC)
twangme7
I took your instructions and was able to remove the leaking pump. I ordered a new one from you, installed it and now my machine works great. Thank you so much!
#4 Posted : Wednesday, September 8, 2010 12:06:24 PM(UTC)
You are welcome. We are glad you were able to fix it.
Guest (4)
