Buddy3534
#1 Posted : Tuesday, July 6, 2010 10:14:55 AM(UTC)
Buddy3534
Amana oven, ARG7302ww, will heat and reach the temperature desired. But as soon as it reaches the temperature, the preheat light goes on and the temperature begins to drop
#2 Posted : Tuesday, July 6, 2010 2:07:53 PM(UTC)
Originally Posted by: Buddy3534 Go to Quoted Post
...But as soon as it reaches the temperature, the preheat light goes on and the temperature begins to drop...
Cancel the cycle at this point and start it over with the same temperature set. What it will do? Check if the igniter will glow.
Here are the breakdown diagrams and Replacement parts for AMANA ARG7302WW Range - S/c S/i Ddraft Gas | AppliancePartsPros.com
Buddy3534
#3 Posted : Tuesday, July 6, 2010 6:58:22 PM(UTC)
Buddy3534
It still goes to preheat and loses temperature. However, the igniter does not glow. I will call for part ( Amana arg7302ww, MFG # P1143343nww )
#4 Posted : Tuesday, July 6, 2010 7:16:51 PM(UTC)
If there is no 120 VAC to the oven igniter while the control calls for heat, replace the control board. You have to order the new overlay as well because it's glued on.
- The control board Part number: AP4041660
- The overlay Part number: AP4040618
