paolito
#1 Posted : Tuesday, July 6, 2010 10:10:49 AM(UTC)
paolito
my ice maker drips some water into the icepan making the ice to stick, is the water valve the problem?
#2 Posted : Tuesday, July 6, 2010 2:01:42 PM(UTC)
Is the ice maker overfilled with water?
If yes, then the problem is a bad water inlet valve.
If no, then the ice maker itself is leaking and has to be replaced.
- The water inlet valve Part number: AP4303451
