Hi guys help, The display window will not stop blinking. When the time is on dislpay. I tried unplugging it but did not work. Thank" Guys
Sounds like the problem is a bad clock/timer. You have to order the new overlay as well because it's glued to the clock/timer. - The clock timer Part number: AP2125564
