Model MDBD850AWW, ran fine until last evening when the wife complained about a, "funny noise." Appears that the pump keeps running after the water is gone. I removed down to the Rinse Arm Assembly, and found and removed much cruft (torn plastic, twist-tie, etc.) from lower wash arm and beneath.
Am reluctant to remove farther until asking the pros here...my current assumption is that whatever switch shuts the pump down once the water is gone is blocked by another strip of plastic junk, but then I've been all wet before.
Would greatly appreciate any advice and suggestions.
THIS FORUM IS DEAD!!!!!!! |
