Can't remember what the original failure was, but it was fixed with resoldering one of the relay pins. It worked good for about 2 months, then failed again, this time diags test shows a 2, heating fault. Got the bottom disassembled and replaced thermostat, aquasensor and hi-low microswitch checked good. Reran the diags test and now it displays fault code 1, which is the aquasensor, checked the ohm test on the 3 brwn wires which go into the control module(aquasensor) and got infinity(should be around 1 MEG) per manual. Aquasensor checks the rinse water and if still dirty adds another wash and rinse cycle to program. Dishwasher gets down to about 6-9 minutes then adds another 20 mins or so and gets stuck on 1 minute forever. I have to hit the cancel/drain buttons to quit. This happens on every wash program. This model and many more that i can tell from this site is so flakey I am about ready to junk this thing---seems to be inconsistent with the diags test results. My guess is the aquasensor($40) or the control module($140). If anyone has replaced an aquasensor I would like to know what the failure symptoms were before replacement. I have been posting my repairs on this site. Any help appreciated before this becomes a boat anchor! Swimming in Seattle
