onewheat
#1 Posted : Monday, July 28, 2008 5:26:30 PM(UTC)
onewheat
The dryer will not start. The motor does nothing, no hum, no click, nothing. It turns freely as does the drum. However the heating element starts heating as soon as the timer knob is turned into a heating cycle without pressing the start button. It does so on the low heat and both of the high heat cycles, but nothing on the air dry cycle. The motor does nothing on any of the four cycles. Any ideas? :confused:
#2 Posted : Tuesday, July 29, 2008 1:48:29 AM(UTC)
Check for burnt wires to the motor start switch mounted on the side of the motor.
