replaced defrost timer @ t.stat ...heater working refrig/65 freezer/20
thanks frank
Freezer too warm, make sure you defrosted everything and all fans working.
i defrosted all the ice with a heat gun my next step i guess is to check the evaporator motor to see if the fan blade is turning ,i know motor is running but no air going into refrigerator what do you think ,frank
Make sure your lower return vent is free from ice.
Originally Posted by: richappy  Make sure your lower return vent is free from ice. can i check it from the refrigerator side?....frank
