djf343@gmail.com
#1 Posted : Sunday, July 4, 2010 3:02:46 AM(UTC)
djf343@gmail.com
My control panel inside refrigerator is constantly beeping .
express thaw constantly go on and off.
had to unplug when temp shot up to reset to get it back to normal but still beeping.
panel problem?
#2 Posted : Sunday, July 4, 2010 5:09:54 AM(UTC)
I looked at your control panel. Seems like an encoder with readout electronics.
I would unplug this encoder. If the fridg now works reliably and the temperatures go to the default settings of midrange, then this control may be bad/intermittant, but I would suspect a bad motherboard AP4436216.
If the fridg will not work with the control panel removed, then I am wrong. I just assume it functions like a normal encoder with knobs.
Control panel beeping and jumping around (Refrigerator & Freezer Repair)
by watrfun 4/26/2013 10:08:23 AM(UTC)
