frankm
#1 Posted : Saturday, July 3, 2010 4:24:03 PM(UTC)
frankm
i checked back wall of freezer iced up
i turned the defrost timer till the heater came on
both heaters worked, i replaced defrost timer@ s.stat, fan motors ok
4hrs ago now its 28 in freezer 65 in frig
were to go now thanks frank
#2 Posted : Sunday, July 4, 2010 8:50:08 AM(UTC)
Your freezer temperature is way too warm. If partially frozen, you have system problems for a pro to look at unless your condensing fan in the back is bad.
