I lost my schematic, and need to know how to connect the wires to my new capacitor. Thanks Whirlpool 18000 BTU AC Model ACM184XKO
Jim
Locate the Run terminal on the compressor ( marked R ) that wire goes to one side of the run capacitor usually has a mark ( herm or a raised solder mark ) the other wire will go to the common bar on the selector switch. On the other side of the capacitor goes the Start Terminal of the compressor No other wire goes with that just one wire from ( S ) on compressor to capacitor ;)
