bob4843
#1 Posted : Thursday, July 1, 2010 6:54:44 PM(UTC)
bob4843
the washer will fill, than it buzzes with a slight odor like a stuck solinoid, than after a while it will start and finish cycle
sidfink43
#2 Posted : Sunday, July 4, 2010 5:44:06 AM(UTC)
sidfink43
Three possibilities, the capacitor, the switch on the motor or the motor itself. The motor itself is more likely but try changing out the other two first.
bob4843
#3 Posted : Sunday, July 18, 2010 7:42:18 AM(UTC)
bob4843
I replaced the capacitor, and starter switch on the motor, I checked continuity on the motor windings, no open circuit. the unit still hums after fill up, then the thermal overload kicks in, at least now I can move the timer switch to spin and drain out the water, could it be the timer switch, or cycle switch? For being less than 4 years old, and the fact it cost $430.00 I am ready to chuck it
sidfink43
#4 Posted : Sunday, July 18, 2010 6:07:52 PM(UTC)
sidfink43
I think it is the motor, unusual, but it could happen.
#5 Posted : Monday, July 19, 2010 1:42:42 AM(UTC)
It could also be a bad timer as it works in spin. Timer AP3721800 about $137
sidfink43
#6 Posted : Monday, July 19, 2010 8:48:46 AM(UTC)
sidfink43
Richappy is right if it spins; I got the impression it it did not spin but only drained. Check the coupling if that is the case.
