The glass cooktop broke on my whirlpool range and I am replacing it, is there anything special on how to replace it or is it pretty much just plug and play?
Its pretty much Un-plug and play. If you know how to turn off the circuit breaker, remove the stovetop, remove 6/10 phillips screws around trim, replace glass and reverse steps you should be good to go play some golf.
