SORE-BACK
#1 Posted : Wednesday, June 30, 2010 3:09:26 PM(UTC)
SORE-BACK
i CANNOT FIND DEFROST TIMER, i HAVE LOOKED EVERYWHERE IT IS SUPPOSED TO BE. PLEASE HELP
SORE-BACK
#2 Posted : Wednesday, June 30, 2010 3:51:03 PM(UTC)
SORE-BACK
Is There Only A Defrost Timer Board And No Timer????????
#3 Posted : Thursday, July 1, 2010 3:12:36 AM(UTC)
Yes it will only have an adaptive defrost board.
I cannot find info on this specific unit so am doing some guessing.
Try hitting the door switch 5 times in less than 6 seconds this may force a defrost cycle. The fans and compressor will shut off if this works.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer board needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms (note some are 240 Kohms) when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
