woody doherty
#1 Posted : 15 years ago
woody doherty
Draft beer dispenser is running too hot what should i do?
#2 Posted : 15 years ago
A make and model may help others help you.
Often though technical data is not available for these units.
Also you did not say what is too warm.
If it is a unit that uses a compressor check that the compressor is running.
If no then it may be a thermostat problem.
If yes and the unit is frost free, it may be a defrost problem or a sealed system re: low freon etc.
Here are a couple good sites on fridge repair.
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
http://www.applianceaid.com/frig.html
If it uses a peltier cell then it could also be a thermostat problem or the fan is not working.
