Nothing on the control panel seems to work. Light inside does come on, door switch does turn that light off.
There is no response when any buttons (to select settings or start) are pushed, they do not light up nor "beep" when pressed as they usually do.
Any ideas?
Thank you,
Jake
Update:
I tried again and it worked, I made no changes/repairs. I did three loads of clothes in an afternoon. The next morning I tried another load (about 12 hours had past since the prior load) and again, no light/beep/response.
The problem seems intermitent. Any ideas PLEASE?
