I am attempting to install a new belt on a 2 year-old front load washer after the previous belt broke. How do I loop the belt over the motor pulley and the drum pulley? I can not find any way to adjust the tension to loosen either to get the belt to reach.
You should be able to just roll the belt on. I don't think there is any tension adjustment on your model.
