My GE washer model WHDSR209G2WW functions in all cycles however, the timer/knob/dial will not advance. Where you start the machine is where it stays. I can wash clothes effectively (fill, wash, rinse and spin all cycles and operations function properly) by simply manually advancing the dial to the next cycle but that is kind of a pain LOL. Please help. Thanks. Your assistance is most appreciated.
Lou
I am having the same problem I hand wrote the model # on one of the drawings
Ok I get 120v across the timer motor coil and then leg to ground I’m getting 88v on one side and 16v on the other side I can hear the timer clicking and every now and then a louder than normal click happens every 30 sec right on the nose….almost like its in a bind---
ok will do and thanks forthe advice
timer is on order and will post finds......thx again!
like you siad it was the timer! Thx for your help!
You are welcome. I'm glad you were able to fix it.
