darth
#1 Posted : Tuesday, June 29, 2010 8:30:36 AM(UTC)
darth
Model no. is a misprint: KUDI24SE BL1 is the right one. I looked at the gasket and can't see any problems except that it doesn't go across the bottom of the door???. What is suppose to keep the water from coming out the bottom?
darth
#2 Posted : Saturday, July 3, 2010 6:59:27 AM(UTC)
darth
Can't anyone tell me, what is supposed to keep water from coming out through the bottom of the door. There doesn't appear to be a gasket on the bottom.
frankm
#3 Posted : Saturday, July 3, 2010 5:56:01 PM(UTC)
frankm
see if water is in drain pan , drain my be stopped up.....
darth
#4 Posted : Sunday, July 4, 2010 7:19:14 AM(UTC)
darth
There is no water in the bottom after using. For now we are putting a towel in the bottom of the door as it is closed to prevent the small amount of water from running on the floor while it is running.
darth
#5 Posted : Monday, July 5, 2010 8:39:08 AM(UTC)
darth
Here is a picture of the inside, bottom at the door. The gasket only covers the bottom corners and there doesn't appear to have any on the bottom of the door.
UserPostedImage
darth attached the following image(s):
darth
#6 Posted : Wednesday, July 7, 2010 12:06:59 PM(UTC)
darth
Now I am really confused. I took off the kick panel and the access panel. The top of the access panel shows deposits like it has been leaking for a long time, but there wasn't any sign of water now, so I left the panels off so that I could see where the water is coming from and ran the dishwasher trough it's cycle twice and not a drop.
My wife had put a towel between the bottom of the door and the lower panel when she discovered the rug under the door was soaked. The towel would be soaked every time we used it. But now, no water?????
