one of the springs broke and I had to take the door off I repaired the spring but I can't remember how to put the door togather. All wiring is in tack except for one ground wire at the bottom of the door. The brackets that attach to door and spring are bent but the screws I have that I took off don't seem long enough and I have the bottom off too. Is there a instuction step by step besides the manual I have that tell you what screw is used for what part of door and which needs the nuts ?
Thanks, Kstirle
:rolleyes: :) :p :o :eek: :cool: Originally Posted by: kstirle  one of the springs broke and I had to take the door off I repaired the spring but I can't remember how to put the door togather. All wiring is in tack except for one ground wire at the bottom of the door. The brackets that attach to door and spring are bent but the screws I have that I took off don't seem long enough and I have the bottom off too. Is there a instuction step by step besides the manual I have that tell you what screw is used for what part of door and which needs the nuts ? I need detailed information to put door back togather. please help
Thanks, Kstirle
