tontomeme
#1 Posted: : Monday, June 28, 2010 6:46:14 AM(UTC)
tontomeme
I have to replace the filter housing it is cracked. I removed the cover and screws. The water line is connected with a john guess push on elbow. How do I remove the filter housing from the elbow and also the elbow from the water line? I also believe I will have to replace the elbows. How do they install?
FridgeDoctor
#2 Posted : Monday, June 28, 2010 9:13:54 AM(UTC)
FridgeDoctor
Groups: Expert
to remove the connections from the water line, you must press the collar towards the connector, while gently pulling the water line away from the connector.
