I have a Kenmore elite side by side model #106.56702500 and everything stopped working on the front panel after I changed the motor for the ice crusher (Four times). When I was hooking up the wires I accidentally touched the plug to the wrong place on the circuit board that is on the front panel. I saw the lights blink for a second when I realized what I had done, after hooking everything up it’s like there is no power to ice and water dispenser assembly. I double checked everything twice to make sure everything is plugged in correctly and I can’t see anything out of place. Does anyone have any ideas? Thanks
Looks like the dispenser front panel has to be replaced. In order to provide the right part number I need the color of the front panel.
The part number for the white front panel assembly is AP3859549 Gene.
