wb7ccj
#1 Posted : Thursday, July 24, 2008 11:38:42 AM(UTC)
wb7ccj
freezer, icemaker fine.
door acts like no power. no water, ice, or light.
already replaced spdt switch on frame.
my wiring diagram is incomplete.
abadfish66
#2 Posted : Thursday, July 24, 2008 11:51:20 AM(UTC)
abadfish66
Take off the hinge cover at top of freezer door, and inspect the wiring, making sure the wires and connector looks good, you can disconnect it and squeez the female ends a bit to make sure you have good contact when you plug it back in. If that does not fix the problem, then you will be looking at replacing the board.
Part Details - GE Control board, part number: WR55X129
wb7ccj
#3 Posted : Thursday, July 24, 2008 12:33:36 PM(UTC)
wb7ccj
thanks badfish. man, that was fast! i already found the connector; looks ok. will give it a squeeze.
how do i get to that board?? it inside the door, right?
abadfish66
#4 Posted : Thursday, July 24, 2008 12:36:39 PM(UTC)
abadfish66
Pop off the front cover that says ice, water etc. behind that are 4 screws, undo those and the whole assembly will slide out, you will need to disconnect the wire harness attached to the board to remove it all the way
abadfish66
#5 Posted : Thursday, July 24, 2008 1:21:24 PM(UTC)
abadfish66
1 more thing I forgot, when you get the assy out, make sure the micro switch on the right side is being engaged when pressing for ice or water.
wb7ccj
#6 Posted : Thursday, July 24, 2008 1:30:11 PM(UTC)
wb7ccj
you da man, badfish.............thanks
