tombush
#1 Posted : Wednesday, July 23, 2008 1:53:29 PM(UTC)
tombush
Getting an F2 code, meaning "oven over temp". Occurs when setting oven for a temperature (e.g. 375) and setting the timer for a specifed period (e.g. 20 minutes). At end of 20 minutes, timer alarm goes off and can be silenced in the normal fashion, only to start chiming again and again after being silenced. Only way to stop the cycle is to flip the breaker to off and this resets the oven. Question: Is the problem a bad oven temperature probe (part #AP3363354, only $24.92) or a bad timer (part # AP2140810, $209.36...might as well buy a new oven if it is the timer as oven is 18 years old)? I will try to eliminate the timer by setting the oven to 375 and NOT setting the timer to see if the F2 code appears along with the "alarm tone" (which I assume sounds like the "timer alarm tone").
Whichever part needs to be replaced, please describe the "remove and replace" process.
Thanks!
Tom
fix2008
#2 Posted : Thursday, November 6, 2008 5:37:30 PM(UTC)
fix2008
My dad just went through the same problem with ours. Although we were getting the F2/F3 error code. What you need to do is use an OHM meter and test the probe on the back of the oven. If the readings are correct (which ours was) then you probably need a new control board/timer. That's what my dad just bought and he hooked it up and bingo it works! Good luck!
Is it safe? Can I use electric oven again after POP noise and breaker tripped? (Oven Repair (including Ranges and Cooktops))
by Guest 3/2/2024 5:41:59 AM(UTC)
KitchenAid builtin electric oven (Oven Repair (including Ranges and Cooktops))
by Guest 1/10/2024 5:07:18 PM(UTC)
F2 Error Code on GE Electric Oven (Oven Repair (including Ranges and Cooktops))
by Guest 9/11/2023 6:33:44 PM(UTC)
Whirlpool Electric Oven Convect Broil (Oven Repair (including Ranges and Cooktops))
by Guest 8/12/2022 8:27:28 AM(UTC)
GE Electric Oven - Won't stay on (Oven Repair (including Ranges and Cooktops))
by tstwingirls@yahoo.com 2/23/2022 3:51:15 PM(UTC)
Frigidaire electric oven model number PLEF489CCF (Oven Repair (including Ranges and Cooktops))
by Guest 7/25/2021 4:06:10 AM(UTC)
LG LSE3092 Electric Oven (Oven Repair (including Ranges and Cooktops))
by cycle70 4/10/2021 11:11:00 AM(UTC)
GE Profile electric oven will not turn on (Oven Repair (including Ranges and Cooktops))
by toddlamp 3/31/2021 7:03:39 PM(UTC)
ge tru-temp electric oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/17/2021 4:26:18 PM(UTC)
Monogram electric oven not heating (Oven Repair (including Ranges and Cooktops))
by Norploc 2/26/2021 12:56:03 PM(UTC)
ZLINE RA36 ELECTRIC OVEN (Oven Repair (including Ranges and Cooktops))
by AndyGray 1/21/2021 5:13:45 AM(UTC)
Help! GE Profile Electric Oven PT916SMSS (Oven Repair (including Ranges and Cooktops))
by Marsa 5/9/2020 8:36:48 AM(UTC)
Electric oven panel issue? (Oven Repair (including Ranges and Cooktops))
by nhreprops 11/23/2019 10:59:26 AM(UTC)
Can I use the electric oven without the broiler heating element? (Oven Repair (including Ranges and Cooktops))
by Al Thumbs 3/16/2019 10:53:19 AM(UTC)
KitchenAid Electric Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by frosini 10/1/2018 7:23:00 AM(UTC)
