Little River
#1 Posted : Wednesday, June 23, 2010 6:37:24 PM(UTC)
Little River
Dishwasher stopped working a few weeks ago due to a faulty start switch on the control panel / user interface. All the lights were lit and the buttons would respond to input except for the start switch. Ordered a new user interface from here (part #AP3177796), swapped it out, and the machine was working like a champ again.
A few weeks later (last weekend) it stopped mid-cycle with a tub full of water. This time there were no lights, no button response, nothing at the control panel. Checked the house breaker - fine. Checked the junction box under the toe-kick - 120v fine. Ordered a replacement user interface, swapped it out today, and still nothing!
What should I be looking for / at? I read the article on continuity testing, but I'm still not sure if that's what I should be checking on this unit for the described issue (I have a digital multi-meter). I'm a builder, so I can manage my way around most technical things, but I'm not sure where to go from here on an appliance repair. I need to get this thing running again before my kids generate any more dishes and my wife makes me sleep in the kitchen sink!
#2 Posted : Thursday, June 24, 2010 1:53:56 AM(UTC)
Replacement parts for WHIRLPOOL KUDP01FLBL5 Undercounter Dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208564040.pdf
I would check the thermal fuse Item 6 in Section 2.
If you replace it be sure to also use the new harness which comes with it.
Little River
#3 Posted : Thursday, June 24, 2010 1:19:56 PM(UTC)
Little River
Denman,
Thanks for the advice. I checked the thermal fuse and it was blown (open / no resistance). A local shop had one on-hand so I grabbed that for the sake of making my wife happy. I swapped it out and the machine is back and running again. WooHoo! Thanks for getting me out of the doghouse.
