wantoineb
#1 Posted : Wednesday, June 23, 2010 7:52:03 AM(UTC)
wantoineb
antoine: gew9250pw1 whirlpool eletric dryer. suddenly only the inside panel light comes on when the door is open non of the other control bottons work
Cindy W: do you know what part you need?
antoine: I have narrowed down to either control board or the consel board? i do not know which one to order
Cindy W: Please Click Here. The link will take you to a page on our Repair Forum that explains how to register and post a question.
antoine: parts #ap3775548 or ap3775940
I need to order either part but do not know which
#2 Posted : Wednesday, June 23, 2010 10:25:51 AM(UTC)
Can you be more specific on the problem, please?
What exactly is wrong and which tests did you run?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GEW9250PW1 Electric Dryer | AppliancePartsPros.com
wantoineb
#3 Posted : Wednesday, June 23, 2010 11:21:24 AM(UTC)
wantoineb
The dryer inside lihgte comes on when you open the dryer door. Other than that nothing power up.
I have tried the trouble shooting by manifacture ... But non of the bottons activate any thing... it will not go in test mode either. All tested the circute below for 3 or 4 diffrent elment below the dryer drum all seem to check ok.
According to the manifacturer thr touble is eithe in the control board or the consel eletronic control board behide the control buttons. and the say you cannot check those boards... help???
#4 Posted : Wednesday, June 23, 2010 11:35:53 AM(UTC)
Perform the troubleshooting test #1 as described in the Tech sheet (page 3) and post the results. You will need a simple multimeter.
wantoineb
#5 Posted : Wednesday, June 23, 2010 12:30:19 PM(UTC)
wantoineb
diagnostic test # 1 did not display any thing at all... ((Pressing less time mopre time in sequence)) no light no sighs of life...
#6 Posted : Wednesday, June 23, 2010 12:54:44 PM(UTC)
Please click on the link, find and perform the test. The test you refereed to is a different.
wantoineb
#7 Posted : Wednesday, June 23, 2010 3:25:29 PM(UTC)
wantoineb
OK did that all cicuit 1 thru 7 were all ok did not have a control board to change and could not check it
#8 Posted : Wednesday, June 23, 2010 4:45:45 PM(UTC)
The step 8 in the test #1 says: If the dryer still does not operate, replace the machine control electronics (#57 on the diagram).
- The machine control electronics Part number: AP3775548
wantoineb
#9 Posted : Saturday, June 26, 2010 5:52:17 PM(UTC)
wantoineb
I changed the system contol board and voila the dryer worked as before thanks
#10 Posted : Sunday, June 27, 2010 3:25:03 PM(UTC)
You are welcome. I'm glad you were able to fix it.
whirlpool duet dryer will not power up (Dryer Repair)
by tpmapes 7/7/2014 8:27:17 PM(UTC)
