Amana dryer, when running squeeks and then grinds. I think the grinding is from the belt slipping because the rollers are bad. I just wanted to get ur opinions to see if I'm on the right track and also, what parts will I need to complete the job?
Besides the rollers you may want to check the front glides (#11 on the diagram). - The dryer drum glide (has to be ordered two) Part number: AP4046795
