billg13
#1 Posted : Tuesday, June 22, 2010 3:22:55 PM(UTC)
billg13
Dryer is exactly 5 years old. It takes a while to dry clothes. I have had this problem before so I did clear out a clog in the vents. In fact there was a dead bird in the tube from the dryer to the wall. But I cleaned everything out including the link chute assembly in the dryer. I did notice that when I first turn on the dryer, there are flames in the heater box. They stay on for about 4 minutes and everything gets red hot like it should. Then after 4 minutes the flames go out. In exactly 55 seconds a will see a glow from the bottom of the heater box but no flames like when I first started the dryer when it was cold. The glow only stays on for 5 seconds. Then in 55 seconds it comes on for 5 seconds and this happens over and over again. Any thoughts? I sometimes think that the original clog might have caused another problem.
billg13
#2 Posted : Tuesday, June 29, 2010 5:13:56 PM(UTC)
billg13
Does anyone have any thoughts on my question above
GE Dryer dries slowly (Dryer Repair)
by elsarrazin 12/20/2010 12:21:18 PM(UTC)
Amana Dryer dries slowly, and More/Less Dry Timer does not advance (Dryer Repair)
by dtshenoy 4/13/2009 6:24:55 AM(UTC)
