nagchunn
#1 Posted : Tuesday, July 22, 2008 7:13:14 PM(UTC)
nagchunn
UNSURE HOW OLD THIS STOVE IS, BOUGHT OUR HOME 2 YRS AGO, IT CAME WITH IT. THE PROBLEM STARTED YESTERDAY. WHEN I TRY TO LIGHT THE 4 BURNERS, THEY WONT LIGHT. THERE ISNT ANY CLICKING SOUND AT ALL. THEY WILL LIGHT MANUALLY WITH LIGHTER OR MATCH, AND THE OVEN AND THE BROILER WORK. JUST NOT THE BURNERS. I CLEANED THE STOVE TOP 5 DAYS AGO, AND THE BURNERS DID LIGHT RIGHT AFTER. WOULD HELP IF I KNEW WHAT PART IS NEEDED TO REPAIR THIS PROBLEM. THANK YOU: nagchunn
SublimeMasterJW
#2 Posted : Tuesday, July 22, 2008 7:38:20 PM(UTC)
SublimeMasterJW
SublimeMasterJW attached the following image(s):
SublimeMasterJW
#3 Posted : Tuesday, July 22, 2008 7:41:13 PM(UTC)
SublimeMasterJW
Pull out the bottom drawer and look for a shielded part...oopz their it is. If it ain't there then it will be mounted behind the control panel. You would remove all knobs and the control knob cover to reveal this animal.
