Replacement parts for WHIRLPOOL KSRA25CNSS00 Refrigerator | AppliancePartsPros.comHere is the tech sheet
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%20W10142174.pdf[COLOR="Blue"]
freezer iced up so badly it stopped the flow of cold air to refrigerator. [/COLOR]
Does sound like a defrost problem.
[COLOR="Blue"]
Is it possible that the defrost timer is not working?[/COLOR]
Yes
[COLOR="Blue"]
where IS the timer on this model? [/COLOR]
Defrost is controlled by the main control board.
See how to force a defrost in the tech sheet.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle. The fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the board needs replacing, re: it is probably never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, around 25 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
