My washer has periodically been leaving the clothes sopping wet. I have run thru several test modes T11 and T14 which it does do the high speed spin 1000rpm but sometimes in the T11 test mode it will run up to 400 rpm then it runs up to 1000rpm and then shuts down, display goes blank except the DOOR LOCK is lit. It does not return to test mode and has to be unplugged and restarted. The hidden drain is clear and it pumps out just fine. The Inverter Drive was replaced just over a year ago but I dont think its a drive issue? I am thinking it might be a control board? Any advice would be great. Thanks
I am pretty sure its the control board now, it has gone from bad to worse. The machine cuts in and out very frequently now goes completely dead as if the unit was unplugged then comes back on to resume cycle stays on for a about a minute then dies again. I checked the control board and it is getting line power when it cuts out. http://appliancejunk.com/ge/washer/31-9135.pdf
Sounds good. If you purchase the part from this site and it does not fix the machine you may be able to return it. See the returns policy for APP.
Good luck, and let us know how it turns out.
