fintasticmp
#1 Posted : Tuesday, July 22, 2008 1:10:53 PM(UTC)
fintasticmp
My Electric Duet Dryer will not turn on I push the power button and there is nothing. There is electricity running to it because the light is on inside. Could it be the panel board and if so which one there is 3.:confused:
misterfixall
#2 Posted : Tuesday, July 22, 2008 3:03:40 PM(UTC)
misterfixall
posibbly the thermal fuse is defective, check for continuity between the 2 terminals if not there replace it. it is white in colour .about 1 1/2 inches long ,made of plastic,
vlad
#3 Posted : Wednesday, July 23, 2008 11:17:13 AM(UTC)
vlad
If the light is on with the dryer door closed - check the door switch.
