All of a sudden the oven would not bake or broil. Checked voltage at L1-L2 = 245 VAC. Check voltages @ relay board. Violet (broil) and yellow (bake) to grd = 101 VAC? Checked Hi rise for continuity = 0 ohm. Removed both heating elements. Broil = 16 ohms, bake = 20 ohms. Checked orange and yellow teminals to bake element, orange = 127 VAC, yellow = 0 VAC. Rechecked relay board with elements unplugged. Violet and yellow now read 0 VAC. Suspect the measured relay board voltage was coming through the hi rise and the heating elements. If so sounds like both relays failed at the same time? or does the relay board have a DLB relay for bake and broil? If this all sounds OK, looks like we need a new relay board.
