I have a Samsung RS2556SH that i can not find the leak on? everyday I have a small amount of water on the floor at the front right of the unit and i can not find out where it is coming from? i have pulled the unit and it is not leaking from the ice/water line? Can anyone tell me what this might be? Thanks Ray
Originally Posted by: rmhenry55  I have a Samsung RS2556SH that i can not find the leak on? everyday I have a small amount of water on the floor at the front right of the unit and i can not find out where it is coming from? i have pulled the unit and it is not leaking from the ice/water line? Can anyone tell me what this might be? Thanks Ray Refrigerator defrost automatically every 6 to 12 hours. The water collects in a drain pan then evaporates. Check the drain pan to make sure it is in the proper place.
